Fule gauge not working.
Old Aug 19, 2007 | 12:47 PM
Allanon's Avatar
I filled up the tank on my 05 Screw yesterday, and when I get back in and start it it still shows less than 1/4 tank. Yes, I checked to make sure there wasn't 25 gallons of gas on the ground Any thoughts????
Old Aug 19, 2007 | 05:35 PM
Steve83's Avatar
Did you leave the key on during filling?
Old Aug 19, 2007 | 07:03 PM
Allanon's Avatar
No sir, I always shut her down all the way.
Old Aug 20, 2007 | 07:31 PM
Steve83's Avatar
Then I think you'll have to take it to someone with a scanner that can read the PIDs going into the cluster. AFAIK, that's the only way to know if the fault is in the cluster, or outside (possibly in the tank).
You might be able to check the resistance of the level sender at the tank, but I'm not sure what it SHOULD be or which color the wire is on an '05. It might be Y/Wh, Y/LB, or DB/Y and it should PROBABLY be between 16(E)-160(F) Ohms to ground.
Old Sep 9, 2007 | 02:04 PM
Meatwagon's Avatar
Truck might be off - but is the key still in the cylinder? Same thing happened to me (and a few other members)... shut off truck, key still in cylinder, fill up tank, gauge shows 1/4 fill.
Usually takes a few hrs to correct itself. Since then, I usually take the key out with me.
