92 F150 5.0 no fire
Old Aug 16, 2007 | 04:49 PM
rivirobo's Avatar
Cool 92 F150 5.0 no fire
It just died while idling in the driveway. The fuel pump comes on and it has gas. I pulled the coil wire and held it to the coil and no spark while it was turning over. I replaced the coil. No change. The cap and rotor look ok. Any other possibilities?
Thanks,
Rick
Old Aug 16, 2007 | 06:34 PM
Steve83's Avatar
Get a Haynes manual & a cheap digital multimeter, and follow the ignition diagnostic procedure (usually in Ch.5 Sec.5).
Old Aug 17, 2007 | 09:22 PM
mgsalida's Avatar
You might also check your Duraspark Ignition Box.
Old Aug 18, 2007 | 12:52 PM
Steve83's Avatar
Duraspark wasn't used after '86. But that diagnostic in Haynes will ID the problem.
