Hot Wire
Old Aug 7, 2007 | 12:21 AM
The King's Avatar
Hot Wire
Does anyone know if there is a wire that's hot all the time near the rear bumper of my '03 F 150. I need it to power a cargo light in a camper shell.
Thanks.
Old Aug 7, 2007 | 01:55 AM
Steve83's Avatar
If you have a factory trailer connector...
Old Aug 7, 2007 | 12:42 PM
The King's Avatar
Hot Wire
Steve,
Thanks, I appreciate your reply. I do have the factory tow package and it does have set up you posted. But unless I'm missing something, the only wire that I could use would be the orange wire on the trailer plug and that would be the key on only. I really needed one that would be hot all the time. I quess I'll have to run a wire the length of the truck from the fuse box or battery. Thanks again for your quick reply.
Bob
Old Aug 7, 2007 | 01:25 PM
Steve83's Avatar
My mistake - I thought the battery feed was always hot. Yeah, I guess you'll have to pull a new circuit if you want to do it that way.
Another option (if your truck does NOT have an LCM) is to bring the LG/Y circuit out of the CHMSL above the rear window & connect that to your camper shell. That's the map light circuit, so it's always hot.
If your truck DOES have an LCM, you won't have the LG/Y circuit in the dome light - you'll have LG/Or, which is turned off a few minutes after the key is removed. This shows the LCM wiring colors:
Old Aug 7, 2007 | 02:38 PM
The King's Avatar
Thanks for all of your help Steve. I really appreciate the effort. I think I'll run a fused hot wire to the rear.
Bob
