HVAC lights
Old Aug 4, 2007 | 04:54 PM
hbanter's Avatar
Question HVAC lights
The 3 HVAC ***** below the stereo are no longer lit on my 2003 F-150 XL. What is the best way to fix this? I assume a bulb is blown. Do I have to remove the entire dash to change it? Thanks for your help.
Old Aug 22, 2007 | 07:58 AM
2003fx4sc's Avatar
I am also having the same problem with my 2003 F-150. Does anybody know what bulb i might need? Thanks.
Old Aug 22, 2007 | 08:56 AM
projectSHO89's Avatar
Most likely, type 164.
You just remove the trim piece from around the radio (it just pops out) and HVAC controls, disconnect the PAD and 4X4 (if equipped) switch connectors, remove 4 screws, and slde the control outward.
Steve
