Adding Factory Rke On 2000 F150
Old Jul 18, 2007 | 02:20 AM
rjs21's Avatar
Can u add RKE to power lock equipped 2000 F150...I mean plug and play factory style?? I work at a Dodge store and to do it on their car lines just requires plug in a module and program fobs. TIA
Ron
Old Jul 22, 2007 | 08:16 AM
usnzulz's Avatar
RkE
If your truck has pl and windows from factory more than likely it has keyless enty try turning your switch off and on 8 times if your door locks lock and then unlock all you need is a remote, do not start truck just to the on position. If this works when you get your remote all you do is off and on 8 times ending in the on position hit boutton on remote and doors will lock and unlock again then if you have another remote do it at same time and then turn the switch off and doors will cycle again leaving programming mode.
