99 ford f150 wont crank over
Old Jul 8, 2007 | 10:05 PM
neibert's Avatar
Angry 99 ford f150 wont crank over
i have a 99 ford f150 ,starter went out ,replaced it and it would stay ingage when started it ,then replaced starter again and it would just click ,replaced starter ,cylanoid battery ,cables ,starter switch ,it wont even click now ,i can jump it over at cylanoid but starter stay ingaged ,can someone give me some advise ,thanks ,len
Old Jul 8, 2007 | 10:12 PM
toolmanpei's Avatar
wont crank over !
i just had the same problem with my 1999 , head gasket was gone and filld the cylanders with antifreez causing hyrolic lock , pull your spark plugs and wind it over and see if you get water !
i need to know where some of the vaccume lines go that are connected to the back left corner of the air intake on the 4.2 , there is a 3 barbed vacuume block at the back and i need to know what pluggs into them
Old Jul 8, 2007 | 10:35 PM
neibert's Avatar
my truck is at shop ,ill let you know ,when i get a chance to look ,,
Old Jul 27, 2007 | 06:44 PM
BMisita's Avatar
Toolmanpei
Did you get an answer on the vacuum block wiring?
