Keypad help
Keypad help
I recently bought an 04 SCrew 4x4, loving it, anyway the person I bought it from didnt know the keypad code to unlock the door. I've read where its on the wallet card in the glove box, no luck. Also have read its on the "computer module", but being a novice, I'm not sure where to find such a part. I could also go to my local dealer to get it done for me but I'm not sure if thats gonna cost me any money. All the help you guys could give me would be great.
On the '04+ the factory code is on the BSM / VSM, which on the SCrew is it is behind the rear seat.
Another member took pictures of his rear seat removal here:
https://www.f150online.com/galleries....cfm?gnum=5660
The Gallery above shows how to get the rear seat out.
It is mounted on the '04, and only the rear seat bottom flips up.
If it was that easy, Mike's gallery on how to remove would not be needed.
Here are some typed directions, I took from Mike's pictures, and notes, and assembled into one document.
http://my.voyager.net/~sscully/04and...eatremoval.doc
One big secret.... don't lift up when you release the catches. There is a slight hook on the end of those plastic hooks. They absouloutly will not release if you have upward pressure whe you release the hooks.
