Fog Lights
Old May 15, 2007 | 06:02 PM
STEWARTW's Avatar
Fog Lights
My 2000 F150 4x4 Has The Fog Lights And They Have Wires Pluged Into Them, However The Light Switch Doesn't Have A Position To Turn Them On. My Question Is Has Anyone Any Experience With This Situation? Can I Simply Go To The Local Junkyard And Find The Right Switch And Install It?
Old May 15, 2007 | 08:16 PM
mgsalida's Avatar
If I'm not mistaken, you should be able to pull on the headlight switch to turn on the fog lights. Once the headlights are on, gently pull back on the switch.
Hope this helps.
Mike
Old May 15, 2007 | 08:26 PM
deerhunter17's Avatar
yep mgs is right just where you turn your headlights on just pull the switch back and they should come on. There is a little light above the switch to let you know when your fog lights are on.
Old May 15, 2007 | 09:30 PM
STEWARTW's Avatar
I Feel Sheepishly Like A Da, Maybe I Should Work Harder Trying To Find An Owners Manual.
