Heater and A/C problem
Old May 6, 2007 | 09:48 PM
billme's Avatar
I have a problem and need help with what to look for .
my A/C started blowing hot so i checked and the compressor is working fine.I though it may be low on freon but then i noticed it even blows very hot when just on vent.
Is the heater control switch bad or is there a valve or any other thing that could be bad.Is there a way to test the switch to change it from hot to cold?
Any help would be appreciated.
Old May 6, 2007 | 10:16 PM
torkum's Avatar
If you have a 97 up F150 do a search on temperature blend door.
