Battery light is on?
Old Apr 28, 2007 | 10:00 PM
FADEtoBLACK's Avatar
About three days ago my battery light came on at night and my lights dimmed than got bright again. I reved and no belt noise and everything seemed ok. I thought that was wierd and continued to work. I drive to work about 50 miles round trip and run my lights both ways, working 3rd shift overnights. Absolutly no problems that night or the next night. Today (daytime) I was just cruising and noticed my idle seemed to get higher and I looked down after a few minutes and my battery light is on again and is staying on! I went straight home. The gauge says above middle 3/4 (average place) even when I turn the lights on it doesn't drop much. It starts fine (so far) but something has to be wrong. I remember you can pull the cable off older cars and they should stay running on the alt. I tried that and it died. Does that mean the alt. is not charging enough?? 99 f150 4.6
Old Apr 28, 2007 | 11:28 PM
Bluegrass's Avatar
At 6 years old, it's time for a new alternator. Brushes tend top wear down and stick/float.
Old Apr 28, 2007 | 11:52 PM
sfam198's Avatar
The alternator is most likely dead, but have the battery tested as well. A dead (or dying) battery can kill even a brand new alternator in a matter of a week or so.
Also, on newer vehicles, don't pull the battery cable while the engine is running. You're likely to cause a voltage spike which could damage the computer or other critical components. On older carb'd engines, it wasn't a problem, but these new computer controlled engines are a whole other beast.
Old Apr 29, 2007 | 01:53 AM
LastSplash's Avatar
Your alt crapped itself. I just replaced mine and I had the same symptoms you described.
Old Apr 29, 2007 | 10:02 AM
Thanks everyone. I figured it was the alt. I will have the battery checked tho.
Old Apr 29, 2007 | 10:18 AM
Frmboybuck's Avatar
My superduty did this same thing and I replaced the alt to no avail... Ended up being a corroded fusable link behind the battery. Mine is a 99 also. Might be something to consider if the alt does not fix your problem
Old Apr 29, 2007 | 11:55 AM
rb4123's Avatar
Also check all the battery cable connections. If they are corroded on either end, that will happen too. And the chassis ground cable.
Old Apr 29, 2007 | 04:38 PM
Thanks everyone! My alt. was only charging 11.5 so I replaced it (wow $145) and charged the battery. Checked the battery after and it was weak. Turns out its's the factory one. Not bad, 8 years old and 93,000 miles! New battery and alt. 210 bucks.
