Clearance lights
Old Apr 24, 2007 | 08:03 AM
jpgillespieusa's Avatar
Clearance lights
I have a F250 Super duty and would like to add clearance lights and have two questions.
Is there a kit for adding them?
Is the wiring harness installed by default or will all the wiring need to be installed?
Jimmy
Old Apr 24, 2007 | 03:45 PM
2stroked's Avatar
All of the parts you need are available from your dealer and I do believe they sell a kit version. As for the harness, no, it isn't already there in your truck, but I believe the connector for it is. The biggest things to be aware of on this installation is "measure twice, drill once." And always start with a drill at least one size smaller than you think you need. It's really tough to drill a large hole smaller. Finally, seal everything completely because if you don't, you'll get an ugly leak.
