Fried system?
Old Apr 14, 2007 | 10:13 PM
jrider1700's Avatar
Fried system?
Ok my buddy was helping me with the alt, having some charging issues....well he "checked" the system by removing the battery cable while it was running...you guessed it, it fried something. I think it is the GEM? windows lights ect not working anymore.......HELP!!!!
Old Apr 15, 2007 | 08:27 AM
SSCULLY's Avatar
Did you check your fuses ?
I am dragging this from way in the back of my brain, but I want to say on the 99-03, Fuse #18 ( 16 ) in the battery junction box ( under the hood fuse panel ) feeds a few items in the interior fuse panel. This is a total SWAG on the fuse number, shooting from the hip on it.
Post what MY truck, and body style ( SCrew, SCab std ), and trim level ( XL, XLT, etc ) you have.
I would start with checking the fuses in the Battery Junction box, or the fusable links between the battery, and the feed to the starter relay on the firewall ( common lug for the run to the fuse panels ).
If you do not find a fuse straight away, then let us know how good you are with a meter or test light, so we have an idea of what format to put the directions in ( don't want to get to basic, if you don't need that ).
Good luck
Old Apr 15, 2007 | 09:14 AM
jrider1700's Avatar
I did check the fuses, one, #16 was burned out, replaced it. as soon as i turn on the ingnition it burns out again... I am not that good with this stuff and dont have any meters.....any help is wonderful.......
thanks
Jason
Old Apr 15, 2007 | 12:28 PM
jrider1700's Avatar
its a 1998 f150 4x4 ext cab
put in the new alt.....so that is working fine now, fuse #15 keeps burning out.....controls interior lights, windows, radio.....
is there another fusable link somewhere?
is there a way to manually crank the window back?
and will i do anymore damage if i drive it before finding out whats wrong with it?
thanks jason
