Automatic Head light problem
Old Mar 29, 2007 | 03:24 PM
dlandis03's Avatar
When its dark enough for the auto lamp to turn on it does, but only the parking lights and fog lights. the head lamps will not. when I flip it over to manually turn them on, they work fine. I have checked the fuses and they are all ok. anyone ever encounter this problem? or does anyone have any other Ideas?
Old Mar 30, 2007 | 12:45 AM
Steve83's Avatar
Sounds like a bad relay. Look it up in the owner's manual.
Old Mar 30, 2007 | 08:24 AM
06 So Comfort's Avatar
Are you the original owner of this vehicle? If not, I would suspect that the former owner made a few modifications. Your fog lights were not wired to come on without the headlights, from Ford.
Old Mar 30, 2007 | 08:29 AM
sysman_rick's Avatar
Post
If you have autolamp enables(light sw pulled out & turned to far left position) fog lights will turn on. If you have the owners manual check the autolamp section;there are some settings thereII think).
Old Mar 30, 2007 | 08:46 AM
ameration's Avatar
I see that your truck is a 2005. Let the dealership worry about it, you should still be under warranty (unless you have over 36k).
Old Mar 30, 2007 | 11:35 AM
dlandis03's Avatar
Ok, The Fogs are wired into the parking lamps not the headlights. I am the original owner. There is no relay or fuse for the auto lamps, I spend all night looking for it. The relay does still click when the fogs and parking lamps click on. The only thing I can think of is the headlight relay.
