Reverse light wire color and location
Old Mar 13, 2007 | 03:48 PM
brodyzfx406's Avatar
Does anyone know the location of the reverse light wire INSIDE the cab? I found the one outside, but I need a location of where under the dash I can find the wire. I am hooking up a reverse sensor system. Thanks, 06 F150.
Old Mar 15, 2007 | 04:36 PM
Bluegrass's Avatar
Well, I could be wrong but I have not found a reason why there would be a reversing lamp lead inside the cab.
The cicuit usually is a fuse from the CJB to the transmission selector switch to the backup lights and to the trailer towing circuit if there is one.
If you want a trigger lead, you have to get it on a lead after the TR switch.
Then a color coded wire can be found.
Now if there was a dash lamp or some alarm to tell you the backup circuit was powered, then you would be in luck for a place in the cab.
Make sense?
Old Mar 15, 2007 | 04:54 PM
SSCULLY's Avatar
Here is the thread for the reversing circuit inside the cab :
https://www.f150online.com/forums/sh...d.php?t=233512
This is in the driver's side kick panel. I do believe that this is the reversing circuit from the Trailer Tow adapter, if you have that installed.
