Fast left turn signal dash indicator
Old Mar 11, 2007 | 07:26 PM
kt5672's Avatar
Front, fast flash,,,rear no flash,,Bulb, socket,,not bad, replaced bulb anyway. Help me out,,,,please
Old Mar 11, 2007 | 08:16 PM
N8s93turbo's Avatar
check the fuses?
Old Mar 12, 2007 | 10:30 AM
tex_n's Avatar
How did you determine the rear socket was not bad? If you say it looks fine, that's another story....
Old Mar 12, 2007 | 11:46 AM
2stroked's Avatar
The "fast flash" is an indicator of no resistance at the front or rear - which usually means a burned out bulb. You said you tested the socket. Did you test the bulb?
Old Mar 12, 2007 | 08:59 PM
Bent6's Avatar
25 Year Member
Does it work ok if you only push the lever just enough to make the signals function. If it does, search multifunction switch. It is a common issue.
Old Mar 12, 2007 | 09:16 PM
Lumadar's Avatar
Like others suggested, checks for bad bulbs or fuses.
Old Mar 13, 2007 | 11:21 PM
Erikpn's Avatar
Yeah, I had the same problem, the passenger's side front turning signal bulb was burned, got the replacement bulbs at PepBoys for like 8dlrs, did the change outisde the store of both bulbs in less then 5 minutes.
Old Mar 16, 2007 | 11:00 AM
my97offroad's Avatar
i had this problem on my truck, checked both bulbs and found out that i had a bad wire going into the left tailight, just where the plug goes into the socket it was loose....
