i need even more help
Old Mar 8, 2007 | 07:23 PM
towrig06's Avatar
I ordered a set of driving lights for my truck the other day and when i received them i noticed that the wiring harness is pretty intimidating. i have searched in the forum for help but i know so little about how to wire this up i cant even really search the right question. i notice that some people say the run strictly off the battery instead of hooking in to a hot wire. some people have drving lights on all the time, some only with brights on. if possible i want them on when the lo beams are on. from the wiring diagram i got it shows a ground from the lights, where should i connect that? then another ground from the relay and another one from the switch inside the truck. where should all these grounds be screwed down. also where should i get the power from? it suggest parking lamp or headlight inside or outside the truck. im sorry this is so long but i really have no idea where to start. if i can just get going i am sure i can figure it out. thanks
Old Mar 8, 2007 | 11:47 PM
SSCULLY's Avatar
Let us start with some basic items, to figure out which way we need to go.
1. When do you want the aux lamps on ?
1.1. Any time the parking lamps are on
1.2. Any time the parking lamps are on, and you turn on a switch
1.3. Any time the headlamps are on ?
1.4. Any time the headlamps are on, and you turn on a switch ?
1.5. Only with the low beams?
1.6. only with the high beams ?
2. You state that "wiring harness is pretty intimidating" what does this mean ?
2.1. You don't know positive from Negative ?
2.2. You know + from - ( and where to look for each )
2.3. You know how to use a test light / DC volt meter
3. What is the aux lamp kit you got ?
3.1. Hella / PIAA / Cibi / other brand name
3.2. Brand name, individual lamps
3.3. Brand X kit from AutoZone / Walmart
3.4.4 Brand X individual lamps from Autozone / Walmart.
4. Does the kit have instructions ?
4.1. Yes
4.2. YEs, but they are rubbish
4.3. Yes, but they are in French, and I failed French in High School, from chasing tail
4.4. Yes, but they are in Spanish, and I can only ask for a beer and a sexual favor from a woman in Spanish.
Those are the major questions with suggested answers, but feel free to expand on the answers, I was just giving some examples, I might not have gotten close to what you are thinking.
Once we get these answered, we should be able to get you on your way.
