Rosin Core ...Right?
Old Mar 4, 2007 | 04:52 AM
jbrew's Avatar
Rosin Core ... Right?
Drawing a blank on this , well , - Totally out of solder and I can't remember the last time I myself needed to purchase, some.
Theirs always solder around ... somewhere
I need to repair harness wires later today.
The correct solder is Rosin Core , right? The RMA stuff Not the lead free or Acid core
Anyone use Flux ? You guys still follow up w/heat shrink these days?
I definitely want to be confident it's done right. My most important concern is the coreect solder type, "Rosin Core" - something mildly - active (RMA) solder..
Thanks ,
Old Mar 4, 2007 | 11:48 AM
Steve83's Avatar
Rosin-core is best for electronics, but it only works right on clean copper. Acid is for dirty metals. Lead-free indicates it's for plumbing (potable water), and that usually requires some type of flux to be applied since it has no core. Don't add flux when using rosin-core; that's what the rosin is. Adding insualtion (heat shrink, tape, etc.) is up to you, based on exactly which circuit you're working on, where it is, how you want it to look...
Old Mar 4, 2007 | 01:01 PM
SSCULLY's Avatar
I usually have the best luck with 60/40 Rosin Core. A .032 Diameter type.
This is what I used for electronics around the house.
Old Mar 4, 2007 | 03:47 PM
jbrew's Avatar
Great ! Thanx fella's.
