Turn signals
Old Mar 2, 2007 | 08:40 AM
stonestacker's Avatar
Turn signals
Hey guys
i just bought an 05 150 and the turn signals do not work, i checked
the fuses and all ok. where should i start.
stonestacker
Old Mar 2, 2007 | 09:49 AM
Steve83's Avatar
With the bulbs, then here:
Old Mar 2, 2007 | 07:29 PM
SSCULLY's Avatar
Do the 4-ways / hazzard flashers work ?
When yo say don't work, is this both the front and rear, and the dash has no indicators on it ( the turn icons that flash when the turn signals are on ) ?
Just a quick test prior to getting down to testing the MFS ( which you very well might have to do anyways ).
Old Mar 2, 2007 | 08:43 PM
turn signals
the emergency flashers work fine, but when you turn on the the turn signal
th
er is nothing, like it is getting no power, not even an indicater light.
when i got the truck it had an old steering column in the back, i
wonder if they hooked every thing up when they replaced it.
thanks
stonestacker
Old Mar 2, 2007 | 09:49 PM
off road dude's Avatar
sometimes when im turning left it doesnt engage i winder if we have the same problem
Old Mar 2, 2007 | 11:50 PM
BLUE20004X4's Avatar
I'll bet it's the arm or the connection to it maybe not plugged in all the way. Even if you had to buy a new arm, it's under $100 and kinda cumbersome to install. Whoever you bought it from should warranty it.
