Battery Light Under Wot
Old Feb 28, 2007 | 10:11 PM
GILTYLER's Avatar
Unhappy Battery Light Under Wot
My 98 5.4 A4OD will flicker the battery light under WOT around 4-5k RPM
also negative batt cable is starting to corrode about 3-4" from the neg terminal on the batt any good/cheap replacements for this cable most auto parts say stealer only
Old Feb 28, 2007 | 10:23 PM
Yankee7985's Avatar
Most likely your alternator. You also might want to check your belt and tensioner.
