Installed the OE Door Handle with Keypad
Old Feb 25, 2007 | 07:45 PM
jgonza5's Avatar
Thumbs up Installed the OE Door Handle with Keypad
Installed in 2006 XLT, 02/06 build, and it worked plug & play. Pulled the rear seat to get the code.
Part Number 6L3Z-1522405-AB, $70.22 List Price
Tips:
On the side of the door (above where the VIN sicker is located), there are two black rubber plugs. Pop the top one out from the inside of the door. There is a 10mm bolt to remove, in addition to the two nuts on the back side of the handle.
Once the new one is bolted in, route and connect the wiring harness's quick connects, making sure it clears the window track, before reconnecting the door rod to the lock pawl.
More to follow.
