Cruise control recall from Ford 1/05
Old Feb 24, 2007 | 09:15 PM
Cady's Avatar
Question Cruise control recall from Ford 1/05
My Ford dealer unpluged my cruise control on 3/05. They got the part and put it in 5/05. My cruise control does not work the way it did, You have to hit the set button now to bump up the speed. Has this happened to anyone else. I just found out about this the other day. A friend of mind told me to try it and it worked, why didnt Ford tell me this.
Old Feb 24, 2007 | 09:21 PM
Cady's Avatar
[QUOTE=Cady]My Ford dealer unpluged my cruise control on 3/05. They got the part and put it in 5/05. My cruise control does not work the way it did, You have to hit the set button now to bump up the speed. Has this happened to anyone else. I just found out about this the other day. A friend of mind told me to try it and it worked, why didnt Ford tell me this. It works fine I Just wish they would have told me when I called to tell them that it didnt work.UOTE]
Old Feb 24, 2007 | 09:38 PM
Bluegrass's Avatar
Are you saying the same set button dosn't set the speed in one action to the speed the truck is going?
But the same button bumps the speed up or down.
Can't hardly be, it's the same button.
When the set button is pressed, you should feel, the cruise take over the throttle pedal position.
Old Feb 25, 2007 | 12:02 AM
projectSHO89's Avatar
...and is's quite impossible that the actions of the recall would have caused this symptom, if indeed there is a problem.
Steve
Old Feb 25, 2007 | 01:21 PM
Cady's Avatar
2001 super crew
Yes the same button sets the cruise and bumps it up. hope I am doing this right, I just got in F150online.com.
Old Feb 25, 2007 | 01:30 PM
expy03's Avatar
The set button has always been for setting the speed, and also for increasing speed if needed.
resume is resume.
Coast is to reduce speed.
Old Feb 25, 2007 | 08:04 PM
Steve83's Avatar
Read the owner's manual. It explains exactly how to use the speed control, and all the features.
Old Feb 26, 2007 | 08:23 AM
GIJoeCam's Avatar
Ditto. Sounds completely normal to me.
