f150 headlite problem
Old Jan 17, 2007 | 02:39 PM
runswithscizzor's Avatar
98 f150 headlites quit but highbeam lites up when flashed (pulled back) so appears highbeam bulb is functional. Fuses seem ok? Thoughts welcome. Thx
Old Jan 17, 2007 | 02:44 PM
Question 98 f150 headlight problem
Headlights quit during ice storm. Highbeam lights illuminate when "flashed" "pulled back" so appears highbeam bulbs operational. Fuses seem ok? Thoughts appreciated.
Old Jan 17, 2007 | 02:45 PM
MmmBuckles's Avatar
what kind of bulbs do you have?
Old Jan 17, 2007 | 02:51 PM
98 F150
Halogen bulbs
Old Jan 17, 2007 | 02:57 PM
Halogen
Old Jan 17, 2007 | 04:50 PM
MmmBuckles's Avatar
it might be the switch. since you said that your high beams still work, then its probably has something to do with the ****. or the wireing from the ****
Old Jan 18, 2007 | 12:41 PM
2stroked's Avatar
Do a search on Multi Function Switch (MFS) and I think you'll find both your problem an the fix.
Old Feb 12, 2007 | 03:35 PM
Corktex's Avatar
any luck as I have a similar problem and I am attempting to trace the problem as I have 12 volts at the fuse.
Jon
