Accessories off while engine running
My '84 F150 has developed a wierd problem. The fan, gauges, and blinkers all work when the truck engine is NOT running and the key is in the "run" position. If the engine is running, they do not work. Alternator and battery all appear to be fine. I originally suspected the ignition switch, but since it is in the "run" position when things work (engine off) and when they don't (engine running) I don't think it's the problem. Headlights and tail lights work OK. Any ideas? Thanks
Originally Posted by kraigp
Just a basic 350 V8...
It's a 351.
Yes, it's most likely a bad ig.sw. The Haynes manual has a logic table for it in the last chapter. If you can find an old version with the RED cover (880/36058), that's the best one for your truck.
