Instrument lights
Old Dec 28, 2006 | 07:50 PM
rkd's Avatar
rkd
Instrument lights
My 97 F150 4x4, 4.6, has had some of the instrument cluster lights quit. The one on the far right quit for a month, and before I could get to it, it came back on.
Then the next one to the left went out. Now the ones on the far left are out.
How do I change the bulbs, or is there more to this?
Old Dec 31, 2006 | 08:38 AM
banishedsheep's Avatar
I have a 98 XLT 4.6, that is doing the same thing...anyone here know how to change bulbs on the intrument panel?
Old Dec 31, 2006 | 09:19 AM
Hawkpilot's Avatar
You will need to pull the cluster, the bulbs "twist-lock" into the back of it. It is not difficult, but is a little tricky the first time. Instructions for removing it are detailed in this thread. You might want to check those solder connections while you have it out, too. If your odometer hasn't already started blinking off, it probably will at some point.
