LED Brakelight Question
Old Nov 28, 2006 | 08:45 PM
ronkartz72's Avatar
Hey guys, I just installed a set of LED 3157's on my 02 Screw and the blinker is blinking fast as if I had a blown out bulb. I realise the new set up is fooling the truck into thinking it is blown. Is there anyway to fool it back the way it was without swapping bulbs back? I hooked up a trailer today and now they blink fine, since the regular bulbs are at the end of the circuit I guess. Anyway that's it, thanks!
Old Nov 28, 2006 | 09:31 PM
mgsalida's Avatar
I think you will need to install a resistor in the circuit. There might be another post somewhere on this topic.
Mike
Old Nov 28, 2006 | 09:57 PM
ronkartz72's Avatar
I was thinking the same thing. Just not sure if it will fry when I go to the ground side of the circuit.
Old Dec 3, 2006 | 06:31 PM
mike8179's Avatar
Thumbs up same problem
I just did the same thing you did. My new LED bulbs were blinking fast. I surfed around and found that you have to get a load resistor. I just bought it off of ebay. It is a 6 ohm 50 watt resistor. check ebay. type in load resistor. It should do the job. one wire goes to ground and one wire goes to the turn. hope this helps. cost is about 10-15 bucks.
Old Dec 3, 2006 | 08:33 PM
ronkartz72's Avatar
Talking That helps
I checked the resistance across a regular bulb and found the same 6 ohm resistance. Just wasn't sure if it went to ground would it fry. I will check radio shack first, save on s&h. Nice truck too! Maybe I will figure out how to put pics of mine on here.
Old Dec 4, 2006 | 08:49 PM
mike8179's Avatar
Arrow
I went to the local shack and all they had was smaller resistors. Nothing like a 6 ohm 50 W one. I just opened the truck yesterday and found three wires for the brake light. black - ground, brown - parking lights, and the other...I think it is redish - turn/brake/hazard. Should be easy to install. I will let you know what happens.
Old Dec 5, 2006 | 07:17 PM
ronkartz72's Avatar
reply
I thought about rigging up an old trailer connector with the resistors and taping it up. Just plug it in to the factory connector, take it out when you hook up a trailer.
