Mirrors and adj. pedals not working on '03 S-Crew
Just bought an '03 Supercrew 4x4 and maybe it's just a coincidence... but all of the power accessories seem to work except the power mirrors and adjustable pedals. (Both are completely dead, not intermittent)
User's manual doesn't list which fuse is for either one so I'm hoping they might be on the same circuit. Does anybody know? Can you think of anything else to try?
Originally Posted by Jason139
Nobody has a wiring daigram or knows what fuse this is? I can't believe the user's manual doesn't list a fuse for either one...
page 178 Fuse # 4 : Power mirror switch, Mirror turn signal relays ( this is in the pass compartment fuse panel )
page 183 Fuse #112 : Drivers power seat, adjustable pedal switch ( this is in fuse panel under the hood ).
Kind of unusual that 2 fuses would be out. But check them both ( i.e. RTFM )
The 2001 EVTM ( should be the same as 2003 ) for the power mirrors:
After you check the Fuse #4, pull the switch panel up in the front ( point ) to release the spring clip in the front, and slide forward ( forks in the rear of the panel ) to remove it.
Unhook the connector, and on the Orange w/ light green stripe, use a volt meter to check power on that circuit ( # 956 ) to a known good ground, to see if power is making it from fuse #4 to door switch as a starting point.
BTW : next time you might want to verify the info in the owners manual, prior to posting there is no info, and it might be good to check 2 sources.
