Ford Remote Start Question HELP
Old Oct 25, 2006 | 07:11 AM
supercrew02TIM's Avatar
Does any one have the installation manuals available for the Ford Branded Remote Start System, part # 1L3Z-19G364-BA the Silver Model, I need the Programming information, My Wife has this one in her ford, and some how my son, 18 months go it stuck in service mode, after i resolved that it worked for 2 days, now the 4 chirps indicate that the tach needs to be relearned but i can not figure it out, seems to have only 2 programming banks but not sure which has the learn tach option and such, The Dealer installed this and kept the install guide, I have the Newer Code-Alarm, installed my self but the guides are much different. any help would be appreciated
Old Oct 25, 2006 | 10:06 PM
anyone with access to old documentation on the install/programing
Old Oct 28, 2006 | 01:18 PM
Cabnfever's Avatar
straight from the book......
Tach Programming Procedure
A. insert key in ignition
B. press brake pedal (and hold in)
C. Turn ignition key on and off two times.
D. Release the break pedal
E. The system will respond by chirping the sire/horn two times
F. Start the engine using the ignition key
G. Allow the engine to settle to normal idle speed. The system will flash the parking lights every five seconds once it has learned the engine idle speed.
H. Press the break pedal to exit tack learn mode and turn engine off.
Good luck!!
Old Oct 31, 2006 | 09:29 PM
Thank you.
