mnesbgr |
10-18-2006 07:13 PM |
Battery light sometimes coming on
Alright, here is my new problem and I didn't see anything on here similar so- truck seems to drive fine and no lights under normal driving. When I give it gas and go deep in the rpm's, at the higher rpm's, the battery light comes on for a few seconds and then goes out. I just changed the belt and the problem is still there. My voltage gauge reads fine so I was thinking about hooking a multimeter up and having someone watch it as I open up the throttle. I'm going to double check my ground straps tom. since I do have a body lift and noticed one was broke but it's apparantly been like that for some time. Is the voltage regulator possibly going bad causing excessive voltage at higher rpm's? Any help would be greatly appreciated!
