PIAA driving light install
Old Oct 2, 2006 | 02:18 PM
sclark27's Avatar
Anyone have pics or can take pics of their PIAA driving or fog light install? More specifically the wiring? I have a 2004 SCrew and have the lights installed on the bull bar already but need some help on the wiring. How do I get the switch wire through the firewall? What connection wire on the truck are you tapping into?
Old Oct 3, 2006 | 01:25 AM
cwbpro69's Avatar
I cant get you pictures but i did a similar type of install with five lights on the front.
It will be a very simple install if you bought the switch kit for the lights because everything is already pre wired to the relay and all you have to do is hook to a power, ground and run the "turn on" wire to the switch inside the cab.
Now for the positive wire you need to tap in to under the dash. I believe there is a wire diagram floating around on this site of the new F-150. It will give you the colors of the postive and negative wires running throughout the vehicle. You can also get a voltmeter and check the voltage of the wires under the dash by taking a needle and putting it into the wire you are wanting to test!
There is a pre-drilled hole in the firewall with a grommet. It is on the driver side and is not too hard to miss if you are looking at it from under the hood.
If you do not have a switch kit, the install will take a small amount of electrical knowledge to install. I can help guide you through the connections if this is the case....
Old Oct 4, 2006 | 08:52 PM
sclark27's Avatar
Found the hole to get me through the firewall. The light kit came with the switch and all the wiring harnesses. I will just need to figure out which wires are hot. I would like to be able to turn these on at any time without the headlights being on.
