Which Tail Lights Would Look Better?...
Old Sep 22, 2006 | 10:15 AM
Blk On 24's's Avatar
I have a new 06' Super Crew with 24" Wheels and is getting lowered tomorrow. I have a black rollpan and bumper cover on the way so the whole truck will be blacked out. Whick of the following lights would look the best?
These first lights are LED's. I think I like them best.
Below are the headlights I have ordered so they will need to match.
Looking for opinions here.
Thanks.
Old Sep 22, 2006 | 05:08 PM
nigdonht's Avatar
I like the second ones
Old Sep 22, 2006 | 05:19 PM
me 2
Old Sep 22, 2006 | 05:42 PM
ziggaboo's Avatar
#2 if i had to pick... but the harleys would look nice too
Old Sep 23, 2006 | 12:00 AM
mgsalida's Avatar
I like #2 as well
Old Sep 23, 2006 | 09:08 AM
wow, noone likes the LED's? and since eveyone likes the 2nd ones, why not the 3rd once? they are identical except for the backup light, which is oval on the 3rd ones. id think that would look better?
Old Sep 23, 2006 | 11:15 AM
toolmaann's Avatar
#1... I personally don't like the protrusions.
#2... Would match best to the headlights you posted.
#3... The oval backup while matching the Ford oval theme, isn't the best match to your headlights of choice.
Harley lights?... Hell yeah.
You '04+ folks have been blessed with a great looking OEM light. If anything, I'd consider "Nite Shading" you OEM tails.
http://72.10.43.141/nightshades.htm
Old Sep 23, 2006 | 09:10 PM
eveyone keeps talking about Harley Lights? What the hell are those????
Old Sep 23, 2006 | 10:21 PM
oem ford parts from the 05-06 fleetside HD f150. They are close to blacked out. The headlights are black too!
-Patrick
Old Sep 26, 2006 | 05:17 PM
LoveMy RST's Avatar
I've got LEDs on the back of my 05 Supercrew (top & bottom)----make sure u add resistors so the cruise will work if you change them all. Also have the exact same headlights as the ones u show-----all looks really good together....
Old Sep 26, 2006 | 09:31 PM
snappylips's Avatar
Those headlights are pretty badass. How much did they run you?
SL
Old Sep 26, 2006 | 09:56 PM
do you have any pics of all this? and what did you say a bout the cruise???
Old Sep 26, 2006 | 09:58 PM
SL
not much. $155 to my door off ebay.
Old Sep 27, 2006 | 08:33 AM
LoveMy RST's Avatar
I'm new to this site, but I do have pics------soon as I figure out how everybody else is putting their trucks on I'll add mine-----try to get it on tomorrow------I've got them on floppy, but not with me-------as far as the cruise----the computer in the truck reads the resistance in the incandescent bulbs as the brake peddal NOT being pressed----when u press the brake, the bulbs light & there is no resistance-----w/LEDs there is never any resistance so the computer in the truck "thinks" the brake is being pressed----adding resistors will eliminate this problem. I got mine through superlumination.com for about 8 bucks each (for 2ohm resistors)----also if you put LED bulbs in the front (for turn signals) u may have a fast blink (again---lack of resistance the truck "thinks" a bulb is blown)-----check out the above site (www.superlumination.com) & they can give you some info on which resistors you may need for your application......if you are not replacing you 3rd brake lite w/an LED you may not have any problem b/c the resistance from its bulb may be all you need (I say this b/c I have a DU lighted hitch cover in my receiver & as my cruise worked fine as long as it was plugged in----until I turned on my R blinker [the blinker that causes the duck head to blink]).......I'm by far no expert (barely even a novice)...I've done quite a bit of research over the past few months about LEDs & currently am trying to see if my tail lights are why my brake shift interlock is out now & my truck is in the shop....but that's another post.....
Mike
Old Sep 28, 2006 | 06:47 AM
LoveMy RST's Avatar
I think this worked-----------It did---this will take u to my album also----there are several different views of my truck-----& I ain't no photographer-----
