2003 Harley-Davidson
Old Sep 8, 2006 | 06:44 AM
Hammer Dave's Avatar
KEY FOBS having just moved over to Kent from Somerset, and not knowing my way around yet,can ANYONE let me know where I can get a 2nd keyfob activated around the Kent area. I brought a 2nd one while over in the West Country, and have just found out the original one will not work now. CAN ANY ONE HELP ME PLEASE
Old Sep 10, 2006 | 09:58 PM
mgsalida's Avatar
If you are trying to reprogram your keyless entry remote (key fob), the info
should be in owners manual. If not, hope the following will help:
REMOTE TRANSMITTER PROGRAMMING
NOTE:
* All keyless entry remote transmitters must be programmed at the same time.
* Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
1. Turn the ignition switch from OFF to RUN eight times within 10 seconds , ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
2. Within 20 seconds , press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
3. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
4. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Good luck
