MY low beam head lights dont work?
Originally Posted by travis08
i have a 05 f150 and my low beam head lights dont work but the high beams do work whats wrong?????
Did you check the fuses ? These are Fuse #23 RH lamp and Fuse #25 LH lamp, each fuse is 10 A fuse.
Do you have DRL ( day time running lamps ) ?
If you move the streering wheel column, do they stay ou t( checking for a problem with the connector to the MFS ).
If you use either turn signal, do they start working ( checking for a problem with the MFS ).
Have you had a chance to meter the headlamp connector, to see if power is there on the Dark Green w/ an Orange stripe ( RH ) or Dark Blue w/ a white stripe ( LH side ) ? ( checking if the power is at the connector, and the element in the blub is bad ).
With the ground working, that shows the ground is working ( Black on both ).
Have you installed after market bulbs or do you still have the stock bulbs in ?
Let us know where you stand on these questions, and we can try to get you working again.
