Airbag light
Old Sep 2, 2006 | 05:30 PM
rkd's Avatar
rkd
Airbag light
My trailer turn signals quit last week. In troubleshooting, I may have removed and replaced fuse 2, one of the minifuses in the under hood fuse box. I think it was the airbag fuse. The owners manual had a diagram of the main fuse box, but not of the mini panel that supposedly handles the trailer lights. Had to get that from Alldata. But still did not get a good idea what the airbag problem is.
I did not get the turn/stop lights to work, but the air bag light is on, flashes codes, etc.
After some searching here, it seems pulling the fuse may have caused the airbag code?
If so, how do I turn the light off? Does the light also mean the airbag system is disabled?
Thanks.
Old Sep 2, 2006 | 08:41 PM
projectSHO89's Avatar
The minifues box only has two fuses. One is for the trailer light circuit, the other is for the PCM KAM feed. Neither has anything to do with the airbag system.
The minifuse panel is in my owner's manual is on page 142.
What is the flash code? If a 27, it's the light bulb in the PAD.
Steve
Old Sep 4, 2006 | 02:09 PM
rkd's Avatar
rkd
The fuse was one of the 10 or so minifuses in the main underhood fuse panel. I think it was the fuse was marked as the airbag system. I think removing it before disconnecting the battery, etc, and waiting ten minutes set a code.
Pita!
