Gauges sweep on startup..
Hey guys an girls..
I have noticed sometimes on startup, all the gauge needles on my 2002 F150 Lariat sweep all the way over and then go to the normal position. Anyone know what this is all about?? Doesn't do it all the time, and usually after it has sat for awhile.
ok, since i may need a new battery, i am looking at Optima, possibly a red top. I don't listen to my stereo too often without the truck running, have never run the battery down. My amp isn't huge, maybe 300 watts to the sub. Would a red top be sufficent, or should i pony up for the yellow?
From my experience, you definitely have a temperory "low voltage" problem after start-up. However, I don't believe in throwing parts (a battery) at a problem until I have thoroughly troubleshot the problem and am convinced the part is defective. If the battery is bad, how is it managing to crank the truck? From my experience, low battery voltage will cause the gages to "peg out" as soon as you turn the ignition on; before you even turn it to the start position. As a minimum, take the truck to Auto Zone or Advanced Auto and have them test the battery and charging system before replacing anything. If the battery tests good, check the battery cables, terminals and grounds. Good luck!
NKENN,
Thanks. That was actually my next plan, tonight go home and get the battery tested and the alternator as well. After that i can determine what the real cause is. Hopefully, whatever is cheaper and easier fix!! It's the orginal battery, and i am hoping it's just that..
Battery is the odds-on favorite, other things are slightly possible.
Steve
Originally Posted by LUKE_DUKE
NKENN,
Thanks guys, i checked the battery yesterday, it was down to about 10 volts, alternator checked fine, replaced battery with red top and back on the road! Now i can sit around and wait for Ernesto to decide where he is going.
Luke Duke out
Luke Duke out
