cig lighter outlet dead in 02 f150
Old Aug 4, 2006 | 10:12 PM
slowrancher's Avatar
I replaced the fuse and only 1 of the 2 outlets will work .Is ther something else?02 supercrew fx4 lariet.
Old Aug 4, 2006 | 11:52 PM
SSCULLY's Avatar
SuperCrew has a cigar lighter, and 2 power points ( 12 V power outlets ), each having a seperate fuse ( 3 fuses total ).
Cigar lighter : Passenger Compartment Fuse panel, Fuse #3, 20 AMP
Front Power Point : Power distribution box ( under the hood ) Fuse #1, 20 AMP
Rear Power Point : Power distribution box ( under the hood ) Fuse #12, 20 AMP
This info is in your owners manual on pages 209 - 212 - 213.
Try the other fuse, front or rear depending on what you are talking about, and see if it solves the problem.
