Switched Hot
Old Jul 24, 2006 | 08:17 AM
wstafford's Avatar
Switched Hot
I need to tap a switched hot wire for a fule pressure gauge. Can anyone tell me where an easy tap would be on the drivers side under dash?
Thanks,
Old Jul 24, 2006 | 09:33 AM
projectSHO89's Avatar
Pick a fuse that is switched. Use a fuse tap from Radio Shack to extend one of the legs of the fuse out to a push on connector.
Be advised that once the tap is used, it spreads the contacts in the fuse panel making reinstallation of the fuse without the tap problematic.
Steve
Old Jul 24, 2006 | 10:59 AM
SSCULLY's Avatar
Steve makes a good point about the fuse panel after the fact.
I would have to ask, how much is the draw, and do you want it hot in run position only, or do you want it on the Accy Delay relay ?
Next question, is do you plan on adding any additional items, that you want triggered the same way ( i.e. hot in run position, or accy delay )
Steve
Old Jul 24, 2006 | 08:22 PM
wstafford's Avatar
Steve
The draw will be minimal and will not be used for anything else. I just don't to run all the way over to the fuse block just for the gauge. I don't want to tap the wrong wire and screw up something electronic either. Just thought someone had found a good spot to wire something light duty like this and could save me from messing something up.
Hot on run would be what I need.
Thanks, Bill
