I need help figuring this out
Old Jul 19, 2006 | 12:06 AM
Luke5181's Avatar
Can some one translate this diagram for me?? I understand the run color wires to the spots shown for the most part. What are the headlight looking things?? I have a handful of brown, red and a couple of red/blue wires that I am unsure of where they go. This isn't very clear to me. any help is appreciated Thanks
http://www.electric-life.com/images/...0schematic.pdf
Tical84's Avatar
you may need to post a pic
Old Jul 19, 2006 | 12:08 AM
Luke5181's Avatar
sorry I forgot the link
Old Jul 19, 2006 | 12:50 AM
Luke5181's Avatar
wow, It seems like every problem I need help with no one has ever heard of jeez I got all the wires hooked up but I have 1 extra blue/red wire and am still unsure what the headlight looking things are, I also have 2 lines with fuses
Old Jul 19, 2006 | 09:26 AM
Mister B's Avatar
I labeled a few things for you. hopefully this will help some.
Old Jul 19, 2006 | 10:11 AM
Luke5181's Avatar
Thanks Mr. B, can you tell me by chance where the illumination wire in the truck is located??
Old Jul 19, 2006 | 10:18 AM
Mister B's Avatar
It has been a while since I have done mine, but I believe it was a brown wire up under the steering column area.
Get a test light and find the brown wire and probe the wire with the headlights off and then probe it again with the lights on. if the test light lights up when the lights are on and not when the lights are off, you have found the correct wire.
Old Jul 19, 2006 | 10:34 AM
Mister B's Avatar
This should help you out with finding the correct wires.
Old Jul 19, 2006 | 01:50 PM
Mister B's Avatar
You should check this thread out if you are looking for some downloadable wiring diagrams for the F150.
https://www.f150online.com/forums/sh...-150.part1.rar
Old Jul 20, 2006 | 09:30 PM
Luke5181's Avatar
are these the same for the 05??? If so that will work great! Thanks a lot Mr. B
Old Jul 21, 2006 | 08:52 AM
Mister B's Avatar
Yes, they should be the same, but always test the wire with a test light first to be sure you have the correct wire.
