power window wiring help
Old Jul 14, 2006 | 09:12 PM
Luke5181's Avatar
After you hook up the windows and wire them you should only have 2 wires to run to the truck correct?? Power and ground?? Also where can I tap the power wire into?? I don't want it to be on constantly?? Can I tap into my cigarette lighter wire or is that to small?? I know you can go direct to the battery but that is constant unless you buy a relay and I am unsure on how to wire those.
