Trailer wiring
Old Jul 6, 2006 | 11:38 AM
jcw1979's Avatar
Trailer wiring
has anybody else had an issue with the factory installed trailer wiring connector on their truck. i have the flat 4 pin connector. i think its 3 female and 1 male or the other way around im not sure without it here in front of me. the issue i have is there is no tailight connection in that connector. theres brakes,turns,and 4 ways but no tailight. got any suggestions or answers????
Old Jul 6, 2006 | 06:55 PM
evtide's Avatar
Check this out:
http://www.accessconnect.com/trailer_wiring_diagram.htm
Old Jul 6, 2006 | 08:48 PM
SSCULLY's Avatar
Do you know if the fuses and the relays for the factory tow are installed in the fuse box ?
If you look in the towing forum, there is a sticky with the info in it.
If you look at the Power Dist. box ( fuse box under the hood ) :
Fuse #5 20AMPs, this is the Trailer Tow Backup/Park Lamps.
Relay # 201 Trailer Tow Park Lamp Relay
If either of these are missing ( or blown in the case of the fuse ) the trailer parking lamps will not work.
That is the best place I can think to start looking. I also have the trail tow install directions scanned into a pdf, if you want to drop me an email via my profile, I can email them to you ( this is the '01 version, info also in the sticky already )
