F18 Short
Old Jun 28, 2006 | 05:42 PM
JMC's Avatar
JMC
25 Year Member
The MAF sensor is in the Air filter Box. The three pin plug you are looking at is on the throttle body?
JMC
Old Jun 28, 2006 | 06:59 PM
jcola's Avatar
JMC - Thank you for your patience & knowledge. I found the wires & plug. The red wire registered about 50 ohms, the black/white got a zero and the other two never moved the needle on the meter (the needle sits on the high end, zero is on the other side of the meter display). I also put the red probe on both sides of the fuse circuit and got the same reading of aroun 50Ohms (or 5.0 to 5.5 on a X10 scale). Any ideas on what to do next?
