00 F-150 wiring diagram needed
Old Jun 6, 2006 | 05:29 PM
FOXrider2004's Avatar
I need a wiring diagram for the power leads going to the fuel pump ( Not the part inside the fuel tank) so i can install RFI filter on the power line of the fuel pump
~FOXrider2004~
Old Jun 8, 2006 | 03:02 AM
SSCULLY's Avatar
If you want the circuit for the motor itself it is the Pink with a black stripe for circuit 787 and the black wire for ground. Same circuit that runs to the Fuel Inerita cut off switch.
This is 1/2 the fuel pump module, the other component of the fuel pump assy is the Fuel Tank pressure sensor.
Let me know if you need the other ones.
Old Jun 8, 2006 | 06:46 PM
hey thanks thats what i needed
