'94 F150 Help
'94 F150 Help
We have a 94 F150 truck. It was running fine with no problems. We decide to was down engine while it was cold. After that engine did not want to start. Notice that battery was dead. We recharged battery and truck still did not want to start. We notice that cable wires were hot. We decide to puchase new battery. Truck was able to start for about 20 minutes but when turned off. Truck would not want to start again. Does any one have any ideas of what is happening. Engine size is a straight v6.
Check distributor, check coil got spark. When truck immediately did not start we check distrubutor for water and found it was completly dry. We will check the spark right know but someone metioned to us about the negative/positve cable going to the starter and frame, they looked good from outside but is it is possible that inside the cables is corroded? WE cut cables back 3 inches and notice black and white flakes inside cable and then reconnected to battery with new terminals. Thanks
It sounds like your cables need to be replaced, which very well might correct your problem. I just don't see the link between bad cables and washing the engine.
The engine cranks, you have spark, and you have fuel, but it won't start, correct?
