Problem with Aux Power Point
Old May 31, 2006 | 04:08 PM
Fettman's Avatar
Hi, I just purchased a '04 F150 and I think that the fuse to one of the power points is blown. I think I may have inadvertantly caused a short which blew the fuse, however I am having a problem finding the fuse box. I have my owner's manual and I tried following its directions, but I am still confused. So, if anyone can give me a step by step guide on finding the fuse box I would appreciate it. Thanks!
Old May 31, 2006 | 05:16 PM
SSCULLY's Avatar
The manual does a really bad job of explaining this.
It is in the pass side kick panel, where the fuel cut off is at.
Here is a picture from another topic, but you are looking at the pass side floor as if you were sitting in the seat.
To the right of the carpet edge there, you can see the fuse box, with the access cover and the fuse cover removed.
In the lower RH side of the picture is the trim panel that covers the A pillar.
If you look at the kick panel, kind of towards the top of the trim panel, you will see the finger hole. Pull towards the interior of the truck, and the fuel cut off and the fuse panel are then exposed. You will now know why the Pass side kick panel is so damn thick once you get the access cover off.
Hope this helps.
Old May 31, 2006 | 05:23 PM
Fettman's Avatar
Yeah, we just found it. Thanks for the info!
