cruise control
Old May 21, 2006 | 01:27 PM
firedog's Avatar
cruise control
Hi, my cruise quit working!! hadnt used it in a while and tried to a week ago, and several times since and it wont do anything. Where do i start?? Thanks... its a '97 f150, 4.6 L
Old May 21, 2006 | 07:50 PM
lees99f150's Avatar
have you had the recall performed. if so did you follow up and get the second part done.
Old May 23, 2006 | 12:11 AM
a1snag's Avatar
second part ?????
second part ??????????
Old May 23, 2006 | 01:14 AM
SSCULLY's Avatar
The first part was when the recall was just starting, and Ford was not able to get all the parts out at one time. They had a 2 part recall, where the CC switch was disco'd, then when the parts came in, another notice was sent that the new harness ( or the 2nd version of the new harness ) was available.
I got my recall notice in NOV-05, and they just ehcked the disco I did myself when the recall started ( sans the jumper so the CC would still work ) and then I got the parts notification in late FEB-06 that the parts were in, adn they could finish it.
Old May 23, 2006 | 08:32 AM
Sherry Knorr's Avatar
Cruise Control - does your vehicle have the multi-function switch too?
My cruise control quit working last night after about an hour of driving (up til then it had worked just fine) -- I have a Ford Explorer V8 Limited (2003), not an F150, however, this problem occured on vehicles back when I worked for the Ford Electronics Division (then known as ELD) on several different vehicles with multi-function switches. Sometimes the cruise and/or the head-lights, and/or the wipers would stop working and could be re-activated by simply activating one of the other systems.....yes, really!
After several unsuccessful attempts to activate my CC, getting pretty frustrated since it was late and I had an hour drive ahead of me, I remembered this little factoid about the multi-function switches. So I tried it and it worked! First, I turned the wind-shield wipers on and then off, and THEN tried to set the CC and it worked. Yes, this is a stupid work-around so I phoned the dealership this morning as the vehicle is under an extended warranty.
I am trying to find documented information on this issue--- the service dept. representative said that he hasn't heard of this issue before and I know I HAVE. Does anyone else know about this issue?? I'd like this troubleshot correctly the first time out [warranties do not last forever].
Any information would be helpful.
Thanks!
Sherry
