headlight problem
Old May 7, 2006 | 10:56 PM
john @ks's Avatar
headlight problem
i have a 98 f-150 4.2L and the problem i have is my right headlight on low beam wont come on. when i turn on the hi-beams it turns on. i used 3 different bulbs and it did the same thing. i checked every fuse and still no changed. i checked the plug and it wasn't corroded. i checked and there is no power going to the plug. i asked the dealer and the told me to changed the relays and i bought them. i replaced the ones they told me but still have the problem. so if anyone can help me i would appreciate it.
Old May 9, 2006 | 09:57 AM
SSCULLY's Avatar
A little bit of clarification :
Q1. When on the low position, only the left is work on low, when on high position, both high beams work ? ( i.e. low beam never works on the right side ).
You checked the connector for corrosion.
Q2. Did you use a meter on the connector ?
2.1. This would be to check that the ground on the connector is good.
2.2. This would be with the low beams on, meter on the Dark Green w/ Orange stripe and black ( ground ).
Q3.Are there DRL or Autolamps installed ?
Q4. Which fuses did you check ?
4.1. There are a few different fuses
4.2. I would suspect the PDB fuse # 8 to work, considering the left low beam works. PDB = Power Distribution Box = Under hood.
4.3. Did you check Central Junction box fuse #26 ?
4.3.1. This feeds the right headlamp and the DRL module.
4.3.2. Central Junction box = CJB = inside pass compartment.
4.4. Central Junction box fuse #28 is the fuse for the left low beam.
4.5. Central Junction box fuse #16 seems good, with the high beams working.
Q5. What relay(s) did the dealer suggest you change ?
5.1. I don't know of a relay in the headlamps, fogs yes, DRL, no but there is the DRL circuit, and the DRL resistor.
The fuse #8 in the PDB feeds the MFS, which in turn feeds CJB fuses #26 & #28, then off to the Left and Right headlamps.
Let us know about the clarifications, so you can get on with fixing the problem.
Good Luck
Old May 10, 2006 | 01:52 AM
john @ks's Avatar
Good Luck
Q1.yes on low position only the left works.
Q2.no not yet but i used a test light.
2.1 the ground is good.
2.2 i will have to look what color it was 2mrw.
Q3. i only have the basic kit on my truck. there are only headlights, running lights, tail lights, and the cab light. i dont have fog lamps.
Q4. yes i check the fuses in the cab and under the hood. i pulled every one and checked them.
4.3 yes i did and i even replaced it.
4.4,5 i checked them both and they were both good.
on the relays i can get the part numbers 2mrw and in my book it say the truck has 2 relays for the head lights. one under the hood and one in the passager compartment.
more info on the truck too its a
1998 ford f-150 short bed single cab. 2x4 stx and has a 4.2l v-6 motor. also is a stick and it has no options. its the most basic one u can get.
i will check all the stuff u asked me 2mrw afther work.
thank you for the info and i hope the info i give u is enought to answer a few of ur Qs.
Old May 10, 2006 | 08:37 AM
SSCULLY's Avatar
Q1. The high beam works on the works correctly, right ?
Q2. With the test light inserted from the bulb side, I am guessing that the test light showed no power on the low beam, but on the high beam it showed power ?
Q3. DRL = Day Time Running lamps. What is the trim level, a XL ? If so, it might not have AutoLamp setting on the main headlamp switch. That is DRLs and Autolamp, not fog lamps.
Q4. When checking the fuses, did you use a test lamp or meter to see if there was power in the fuse socket #26 ? This is an internal jumper in the fuse box between both sides.
Q5. Not the part number of the relay, the relay position in the 2 fuse panels. I just downloaded the owners manual in PDF format, and looked starting on page 134 ( actually the relays start on page 138 ) and there is no note of a headlamp low beam relay. I wanted look to look again, as operationally this is how my 2001 was.
I looked in the 1998 EVTM, and the diagram also shows no relays.
