6 bulb headlights
Old Apr 30, 2006 | 01:10 AM
listo's Avatar
Question 6 bulb headlights
This is what i want to do.
When i put my bright light on i want my low beams and my fog lights to stay on.
i have an aftermarket housing for my headlights (seperate bulbs for high and low now) so i dont think heating should be a problem.
does anybody know how i can do this? i saw the fog with high beams mod in the technical articles but i dont really get it and i was wondering if it were possible to use 1 relay for both things.
can anyone explain these to me better than in the article.
Does anyone see any problem with doing this?
if i just make it so the low beams stay on will this make the fog lights stay on as well? (seeing as they will stay on when the low beams are on.)
here is a pic of my headlights
Old Apr 30, 2006 | 03:39 AM
SSCULLY's Avatar
For your MY, start with the Fog lamp switch modification, to have th fogs on with the parking lamps, and the high beams ( FEdEx pilot posted this on his web site, at least I recall it to be both, not just the prking lamps only ?? ).
After you have this, the next step is to power the low beams when the high beams are on.
Easy route, is to add a Relay that the high beams power the coil on, and this closes the N.O. contacts on the relay, that has a feed to the battery on one side of the contacts, and on the other feed both low beams circuits.
Remember to size the wire accordingly :
Each low beam 55 watts.
P=V*I
55=12*I
55/12=I
4.58=I
2 low beams 4.58 * 2 = 9.16.
Using the 80% rule, use 14 AWG wire and a 15 A fuse for the drawing above, and at least a 20 Amp relay.
Let us know if you have any questions, this should cover it ( aside from correctly recalling what FedEx pilots mod covers for when the fogs can be on...that I might have goofed on ).
Good luck !
Old Apr 30, 2006 | 03:51 AM
SSCULLY's Avatar
The mod I was talking about above :
http://www.geocities.com/tedoca/headlight.html
The write up says parking lamps, and with the high beams !!!
Old Apr 30, 2006 | 03:59 AM
listo's Avatar
any idea if this will work with the auto lights feature?
Old Apr 30, 2006 | 11:31 AM
SSCULLY's Avatar
The fog lamp mod ? You would need to search on fog light switch ( or similar ) to see where the ramp needs to be modiied for the autolamp position.
I thought that required additional grinding, but I am unsure at the moment, how much.
Old Apr 30, 2006 | 07:41 PM
PKRWUD's Avatar
I'd check with your local authorities first. In the U.S., in most states, that would be illegal. It's generally accepted that you can't have more than 4 forward-facing bulbs lit at any one time, when driving on surface roads.
Old Apr 30, 2006 | 08:20 PM
listo's Avatar
thanks i never knew anything about that i'll have to look into that
Old May 1, 2006 | 01:17 AM
SSCULLY's Avatar
IL is the law for a max of 4 ( head lamps and aux lamps ) :
Illinois Vehicle Code - 625 ILCS 5, Section 12-211
Number of driving lamps required or permitted.
(a) At all times specified in Section 12-201, at least 2 lighted driving lamps shall be displayed, one on each side of the front of every motor vehicle other than a motorcycle, except when such vehicle is parked subject to the regulations governing lights on parked vehicles.
(b) Whenever a motor vehicle equipped with driving lamps as herein required is also equipped with any auxiliary driving lamps or a spot lamp or any other lamp on the front thereof, not more than a total of 4 of any such lamps on the front of a vehicle shall be lighted at any one time when upon a highway.
(Source: P.A. 86-1236.)
I'm not going to tell someone what to do with their vehicle though, more so when it is outside the borders of N.America
Old May 1, 2006 | 01:23 AM
listo's Avatar
anyone know about canada?
the way thats worded it almost sounds like no more than 4 auxilary lights. (6 total)
4 of any such lamps
your thoughts?
Old May 1, 2006 | 08:31 AM
SSCULLY's Avatar
..<snip>...
the way thats worded it almost sounds like no more than 4 auxilary lights. (6 total)..<snip>...
For IL, that is 2 driving lamps ( Head lamps ) and 2 Aux lamps ( what us common folks call driving lamps or fog lamps ) total.
Subsection (a) is what is written on the ticket, when you get one for having a head lamp out on a car, or don't have your M/C head lamp on while moving, and is what the first 2 of subsection (b) are counted towards.
Old May 10, 2006 | 08:23 PM
listo's Avatar
Anybody know how to do that with this switch?
