1998 Instrument cluster replacement
Old Mar 30, 2006 | 03:32 PM
JHL's Avatar
JHL
My original instrument cluster died, to be specific the speedo died, but the odometer still functions. Since driving by Tach alone isnt the preferred method, I took my 98 to the dealer to have the cruise control issue repaired and had them take a look at the speedo. They said the whole instrument cluster had to be replaced at a parts cost of $600, and labor of $200!!!
I bought a cluster out af a wrecker and now am being told that the truck will not start if I replace the cluster? Something about having the whole PCM reset??? Since my 1998 has the mechanical odometer, cant I just swap the clusters? Or would a battery disconnect reset the PCM?
Please will someone familar with the 1998's electrical system, or a Ford mechanic answer this?
Old Mar 31, 2006 | 10:54 PM
JHL's Avatar
JHL
Exclamation JMC, or anyone who knows older 97-2000 F-150's???
Hopefully someone with the answer will let me know before the weekend is over.
Thanks in advance...
Old Apr 1, 2006 | 01:26 AM
SSCULLY's Avatar
It is a 1998 truck ( no PATS ) and "someone" is telling you it won't start without what ? The PCM has nothing to do with the cluster and PATS if that is what this "someone" is talking about.
Take a look at your key just to be sure, is it the transponder key ( bigger head on the key ) or a regular key ? 1998 should be a regular key, sans transponder.
I PATS was introduced with the digital odometer, which was 1999.
Check you key size, and the odometer type ( digital or mechanical ) to confirm non PATS. If that is the case, just swap with a 1998 cluster from a junk yard, just watch your millage on the new vs. old. Maybe take a picture of them side by side out of the truck, so you have an accurate tracking of the millage on the truck.
Let us know.
Old Apr 1, 2006 | 02:37 AM
JHL's Avatar
JHL
Thanks SSCULLY!
My odometer is mechanical not digital, and the key is the thin type. If it doesnt rain all friggin weekend I will take the dash apart and swap the clusters. The digital photo idea was what I was gonna do, so I have proof of the new mileage vs. old.
I am curious what will happen when I take it in for my CA smog check, what if they notice the miles are less than the last time I had it done?
