auto down not working
Hi all I am having a problem with my drivers side power window.
it works, just the auto one touch down feature is not working.
is this a relay issue? where do I check?
I only have access to the 2002 EVTM for the power windows at the moment, and it shows the one touch down relay, the 1998 owner's manual also shows a one touch down relay ( relay 4 ) in the central junction box.
This is a full size ISO relay, and the only other one out there is the acc delay relay ( relay 5 ). So if Relay 4 is bad and you swap 4 & 5, the tell tail would be none of the windows work anymore ( the acc delay feeds power to the window switch ).
Don't recall if any in the battery junction box are the same as the central junction box ( something like the tow batt relay ?? ). This would be a better swap out to check with.
If the relay swap 4 & 5 works, the next step is to check the switch, but starting with the one touch relay is a good point.
