Permanent 12 volt wiring ... help
Old Feb 24, 2006 | 06:32 PM
timmyjimmy5150's Avatar
I have a 2006 frod expedition & I have a sirius "plug & play" unit I want to permanently mount in my car.
I'm tired of tying up the cig. lighter with powering the sirius as I want my phone charger there.
SO, How can I hard wire the sirius to a constant 12 volt supply w/o/ using the lighter? Can I use the fusebox? How? Other options?
thanks
tj
Old Feb 24, 2006 | 10:32 PM
lees99f150's Avatar
here's how i did my XM on my 99.
i tapped into the radio ignition on power wire and connected a power outlet. (i got a extension cord and cut off one end.) i then plugged my XM into this and hid it all behind the dash cover. my xm only draws a minimal current so the fusing wasn't a problem and it turns on and off with the key.
I'm sure you can do this on your 06. you just need to find a power wire.
