Can Someone Help Me??please.
Old Feb 22, 2006 | 01:49 AM
jonesquincy3's Avatar
My Power Mirrors Have Stopped Working. I Checked The #4 Fuse Under The Steering Wheel, And It Is Fine. I Have Heard There Might Be A Switch Problem, But.....i Dont Know What That Means. I Know That My **** For Moving The Mirrors Is Missing And All I Have Is The Plastic Post To Adjust Mirrors. Both Sides Are Not Working. I Would Like To Fix Myself, But Just Need To Know What To Look For And How To Fix It. Do I Need To Pull Off The Door Panel? What Do I Look For? And How To Fix?.....(also, Does Anyone Know Where You Can Order Small Parts For Inside Your Truck, Like The **** For My Power Windows.)
Anyone Got Any Info On A Good Keyless Entry Place...i Have The Factory Keyless System, But No Fob..any Ideas. Wheres The Best Place To Get One. Are They Pretty Easy To Install.
Hoping You F-150 Guru's Can Come Through.
God Bless,
Derrick
Old Feb 22, 2006 | 11:37 PM
metallion's Avatar
Sounds like the power mirror switch is bad. Replacing the switch will also get you a new ****. The ***** are no longer available from Ford anymore.
Old Feb 23, 2006 | 08:08 AM
projectSHO89's Avatar
Ford dealer can get you a replacement.
Usually available cheaper on ebay, you'll have to figure out which one you need.
Steve
